1998 Toyota Corolla ignition repair
1998 TOYOTA COROLLA
150,000 MILES • 4 CYL • FWD • MANUAL
KERLOVESCARS
Needing a guide or information on how to dismantle steering column to be able to replace the lock cylinder or ingition.
May 22, 2008 at 7:21 PM
KHLOW2008
  • 41,814 POSTS
If you only need to replace the lock cylinder you do not need to remove the steering column.
Just remove the covers and turn ignition to ACC. On the lock housing you will find a recessed pin. Use a pointed object to push the pin in and you can then pull out the cylinder with the key.
May 27, 2008 at 12:53 PM
