The car is running hot in low speed situations. I replaced the left side cooling fan motor, which was dead. I also replaced the thermostat and the coolant temperature switch in the thermostat housing. It is still running hot, and I am thinking there must be a separate fan switch somewhere, but I can't seem to find it. Do you know if there is one? And where it is located?
Thank you...Mike
Thank you...Mike
Aug 23, 2010 at 11:04 AM
