1997 Toyota Corolla windows
1997 TOYOTA COROLLA
118,300 MILES • 4 CYL • FWD • AUTOMATIC
PMP
  • 177 POSTS
hello, my 2 back windows squeak loadly when i roll them up or down there power windows. one of the windows is so bad it gets stuck sometimes. Is there somthin i can spray down the window to fix the problem? Ty
Dec 2, 2008 at 11:47 PM
MMPRINCE4000
  • 8,548 POSTS
It would be best to remove the door panel and spray the regulator with silicone spray, also inspect the dew wipes (the rubber squeege that wipes the window when it goes up and down and prevents water intrusion into door).
If you don't want to remove the panel, then spray WD40 or silicone in the window (rolled down), but it will leave streaks on the window for some time.
Dec 3, 2008 at 5:54 AM
