1997 Toyota Corolla WIERD NOISES WHEN DRIVING. WHERE IS THE
1997 TOYOTA COROLLA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOLORAS1
My car makes popping noises sometimes when I am steering. Could it be the axle, struts or springs?
Also, where is the trunk light located. All manuals state that a certain bulb is used but I cannot find where that bulb is in the trunk.
Sep 11, 2009 at 10:22 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
The trunk light should be in trunk under the rear window. You may have to get on you back and slide in trunk to see it.
Sep 12, 2009 at 8:06 AM
