SHIFTER LIGHTING DOES NOT ILLUMINATE IS IT A BULB OR FUSE PROBLEM?
Mar 17, 2009 at 10:59 AM
MMPRINCE4000
CERTIFIED EXPERT
Check fuses first, otherwise you will have to remove shift console cover to replace light bulb.
Mar 17, 2009 at 2:09 PM
PMP
MEMBER
Its the bulb i have the same car 97 corolla its kinda a pain to get the bulb out make sure you have plenty of time.
Apr 2, 2009 at 2:21 PM
MMPRINCE4000
CERTIFIED EXPERT
Best thing to do is to use car repair manual link in this thread or get a Haynes manual.
The console can be a pain to remove and has to be done in a certain sequence. Once you have replaced the bulbs, check their operation before you reinstall console.
