1997 Toyota Corolla Oil leaks
1997 TOYOTA COROLLA
330,000 MILES • 4 CYL • FWD • MANUAL
KALLIEC
Oil leaks. Needs to top-up power steering fluid every second day.
Is home replacement of seals/gaskets possible?
Regards.
Kallie.
Aug 24, 2010 at 11:33 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Often this is not the case as special tooling is required.
mark (mhpautos)
Aug 25, 2010 at 5:04 AM
MMPRINCE4000
  • 8,548 POSTS
Check if it is leaking from pump or from pressure/return lines.
As Mark said, rebuilding PS pump is not s DIY job, but hose replacement is.
Aug 25, 2010 at 8:06 AM
