1997 Toyota Corolla front brakes lock up
1997 TOYOTA COROLLA
PVT_NICHOLS
Brakes problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Automatic
the front brakes on my car on both sides lock up I changed the pads and bled the lines and it still locks up what's going on here?
Oct 21, 2009 at 9:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
calipers maybe freezing up causing brakes to lock up
Oct 21, 2009 at 9:33 PM
PVT_NICHOLS
I added you on there and need to explain to you the whole thing please
Oct 21, 2009 at 9:43 PM
AVENUE723
  • 9 POSTS
TAKE pads off- try to push in the caliper piston - if they dont push in at all, they are frozen-
you will either need a caliper piston pusher, or take a pair of large pilers/channel locks to squeeze in pistons.
the pistons, (they are round and push on the pad)
should push in pretty easily. Even if they do push in, but are very hard, then they are starting to freeze up.
Oct 21, 2009 at 9:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1102.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_317.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname3_119.jpg
Oct 21, 2009 at 9:52 PM
