1997 Toyota Corolla Brake Lights
1997 TOYOTA COROLLA
SCHWINDT10
My Left Rear brake keeps going out, I've tried fixing it by adjusting the bulb several times & it still doesn't seem to work, I think it might be the wiring that's the problem, what should I do?
Nov 30, 2008 at 6:46 AM
MMPRINCE4000
  • 8,548 POSTS
Check the taillight housing, look for burnt or black areas that may indicate a short. Make sure the area is dry, you don't have a lens crack that is letting in water. When you install bulb, use dielectric grease to help seal the bulb.
Mar 17, 2021 at 6:01 PM
