1996 Toyota Corolla rear turn signal
1996 TOYOTA COROLLA
145,000 MILES • 4 CYL • FWD • MANUAL
FLATTIRE
I replaced the rear turn signal bulb which didnt do anything. I replaced the socket and still nothing would work. All of the other lights in the rear work except the turn signal. The turn signal on the same side up front works... Any ideas?
The rear right turn signal doesnt work. I will be buying one of those things to check if I have power going to it. If there isnt.. Will it be hard to fix?
Feb 20, 2008 at 3:14 PM
Which rear turn signal is inoperative?
Left turn signal has the green and black wire and the Right has the green and yellow wire-activate the turn signal both direction and check for power at both -no power you have an open wire going to that bulb.
Feb 20, 2008 at 3:34 PM
FLATTIRE
[quote:5624977ec0="rasmataz"]Which rear turn signal is inoperative?
Left turn signal has the green and black wire and the Right has the green and yellow wire-activate the turn signal both direction and check for power at both -no power you have an open wire going to that bulb.[/quote:5624977ec0]
The right side is not working.
Feb 21, 2008 at 10:18 AM
Check the green and yellow wire for an open or shorted to ground.
Feb 21, 2008 at 1:46 PM
