Hi
I am not a auto mechanic but want to learn. Therefore if what i write does not make full sense please bear with me.
96 Corolla was having oil in the radiator. Block testing of the engine was done and the color of the liquid did not change indicating it is not likely a Head Gasket leak. Earlier one mechanic suggested Blue Devil to fix the crack in radiator. I put the same; that did not help but now the water pump seems to be leaking and the coolant is going down a bit daily. Replaced the Radiator + Hoses (Radiator was found cracked) and the oil in the radiator seems to have disappeared. Now there is only coolant in the radiator.
I am planning to replace the water pump ; But if there is no oil in the radiator can i safely assume there is no head gasket leak? I have already spent a fortune on this
vehicle.
Thanks
vehicle.
Thanks
Jan 19, 2008 at 12:50 AM
