1996 Toyota Corolla How many extra hours?
1996 TOYOTA COROLLA
145,000 MILES • 4 CYL • FWD • MANUAL
BOBBASURA
If a clutch job is already being done, so the transmission is out, how much extra labor is involved in changing the left and right CV drive shafts?
What does it mean when the mechanic says "It pulled out of the knuckle", referring to why these shafts need to be replaced?
Jun 21, 2008 at 11:12 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The drive shafts are already removed if the transmission is out of the car. What he is describing is the inner & outer portion of the joint has been dismantled, (they will just slide back in) so make sure that they are faulty and need replacing, and that no extra hrs are added as drive shafts must be removed prior to the transmission being taken out.
mark (mhpautos)
Jun 22, 2008 at 3:21 AM
KHLOW2008
  • 41,814 POSTS
Hi BobBasura,
If only the CV joints are replaced, then a little extra time is justified, but not the whole driveshaft assy.
Jun 22, 2008 at 1:24 PM
