my fuel injectors,all four,are spraying way too much gas and flooding the engine.what can cause this
Oct 14, 2008 at 6:41 AM
MMPRINCE4000
CERTIFIED EXPERT
Check the fuel pressure with a mechanical gauge. Also check the fuel pressure regulator vacuum line, if gas is present, it should be replaced. Make sure the FP return line is not blocked.
