trip odometer
1995 TOYOTA COROLLA
114,000 MILES • 4 CYL • FWD • AUTOMATIC
TONYRLW
my trip odometer never moves off 000. what could be causing this and is it something that a "layman" like myself would be able to fix without spending a lot of money?
Jun 15, 2008 at 9:14 AM
KHLOW2008
  • 41,814 POSTS
Hi tonyrlw,
The cluster needs to be replaced are diagrams to help. Check out the diagrams (Below). Please let us know what happens.
Jun 15, 2008 at 11:37 AM
TONYRLW
Thanks for the advice I got a used cluster and everything started working. I love this site. Cost me $70.00
Jun 15, 2008 at 6:34 PM
KHLOW2008
  • 41,814 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jun 16, 2008 at 6:35 AM
MDMILLER1
I compared my 96 corolla odometer to the mile markers on the interstate, and found that it turns approximately 1.626 times faster than it should. I just purchased the car for my daughter, and would like to be able to keep track of the mileage. The speedometer seems to read accurate. The miles are piling up fast. What would cause this? Thanks.
Nov 29, 2018 at 12:22 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Seems the odometer is reading in kph instead of mph.
PDEGFL
1998 toyota corolla LE. 58,000 miles.speedometer and odometer blanked out. replaced speed sensor. After driving a short time, same problem. When i shut the car off and let it sit awhile, speedo and odometer work normal until it trips again. There is no pattern to the amount of time or mileage traveled when it trips.
Nov 29, 2018 at 12:23 PM (Merged)
usually bad connections at either the sensor or the dash cluster.
BRADY B
Electrical problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic
Speedometer and the odometer will shut of and check engine light comes on then after awhile it all comes back on what should I check?
Check engine light coming on
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
JEFFZEEMAN
How do I remove the odometer? I have checked both cables and the gearbox side. All in order.
KHLOW2008
  • 41,814 POSTS
To remove the meter cluster, you need to remove trims etc.
Unplug the cable and wire connectors.
Is the speedometer working?
Did you check if the cable is broken?
