1995 Toyota Corolla remove starter
1995 TOYOTA COROLLA
158,000 MILES • 4 CYL • FWD • AUTOMATIC
VMSESSIONS
how do you remove the starter
Aug 15, 2009 at 12:03 PM
STEVEW84
  • 673 POSTS
Disconnect battery ground cable.
Disconnect the IAT sensor connector
Remove air cleaner hose clamp bolt.
Remove air cleaner cap clips.
Disconnect the air cleaner hose from the throttle body, and remove the air cleaner cap together with the air cleaner hose.
Remove the wire clamp.
Disconnect electrical connectors from starter motor
Remove starter motor attaching bolts, heat shield (if equipped), then the starter motor.
Aug 15, 2009 at 9:14 PM
