Raise and support the vehicle and remove the wheel, caliper and disc.
Loosen the 2 nuts on the lower side of the shock absorber. Do not remove the 2 nuts and bolts.
Remove the cotter pin and nut from the tie rod end.
Remove the tie rod end from the knuckle using a joint separator or equivalent.
Remove the bolt and 2 nuts holding the bottom of the ball joint to the control arm and separate the arm from the knuckle.
Remove the 2 nuts from the steering knuckle. Place a protective cover or shield over the CV boot on the driveshaft.
Using a plastic mallet, tap the driveshaft free of the hub assembly.
Remove the bolts and remove the axle hub assembly.
Clamp the knuckle in a vise with protected jaws.
Remove the dust deflector. Loosen the nut holding the ball joint to the knuckle. Use a ball joint separator tool or equivalent to loosen and remove the joint
Use a slide hammer/extractor to remove the outer oil seal.
Remove the snapring.
Using a hub puller and pilot tools or equivalents, pull the axle hub from the knuckle.
Remove the brake splash shield (3 bolts).
Use a split plate bearing remover, puller pilot and a shop press, remove the inner bearing race from the hub.
Remove the inner oil seal with the same tools used to remove the outer seal.
Dec 18, 2009 at 7:42 PM
