1995 Toyota Corolla burning oil or loosing oil
1995 TOYOTA COROLLA
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAULO
My corolla is consuming extra oil,or loosing oil or burning oil, before the next oil change on 3000 miles I put 2 quarters, but i dont see any oil leak from the motor. how this is happen?
Sep 12, 2010 at 2:05 PM
MMPRINCE4000
  • 8,548 POSTS
If there are no leaks, then it is burning it. Most common would be valve stem seals.
I would check compression also to rule out a bad piston ring.
Sep 13, 2010 at 8:33 AM
