1995 Toyota Corolla Brake and Fuel line repair
1995 TOYOTA COROLLA
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
TJBURKE
It seems I need to have my brake and fuel line replaced. I had lost the brake flued, had the line repaired. The mechanic used brass coupling connections, so I 'm back at square one. The dealer said the fuel and brake line ( I did see the rust on the lines) need to be replaced. The cost is $3729.00. Yes this is a lot but cheaper than car payments.
Is this a legitimate price? Should I shop this around?, should I stay with a Toyota dealer? [email protected]
Nov 19, 2009 at 1:16 PM
MMPRINCE4000
  • 8,548 POSTS
Go to a website called inlinetube.com and check the brake lines out. They have complete brake lines (steel or stainless) for under $500.
Anyone who would use brass compression fittings on a brake line is someone to avoid.
Nov 20, 2009 at 8:30 AM
