1995 Toyota Corolla Blue smoke
1995 TOYOTA COROLLA
74,000 MILES • 4 CYL • FWD • AUTOMATIC
ANDIEG
The car is giving off blue smoke, especially in the morning. Once the engine gets up to temp. the smoke is a little less. A compression test was done and all 4 cyls. read 150psi. I'm not sure what the reading should be. What could be the cause of the smoke? Thanks in advance.
Dec 4, 2008 at 9:17 PM
Could mean valves/seals/rings-recheck the compression both wet and dry test ,also do a cylinder leakge test.
Dec 4, 2008 at 9:58 PM
ANDIEG
Thanks Rasmataz,
I was leaning towards a decarb. Will do those tests, and see haw it works out.
PEACE.
Andie
Dec 9, 2008 at 5:19 PM
