I have a '94 Toyota corolla wagon. It started running hot.Never into the red zone but about 1/2 up to the red. The water pump was bad and was replaced but it is still running hot. I have the fan running all the time. Bypassed the fan switch by disconnecting it. There is a small amount of white on the oil cap. Very small. I did a block test and that turned out good. I have also replaced the thermostat and still the same. I don't know an inexpesive way to check if the radiator is bad . No leaks and the car holds all it's fluids. Stumped any ideas.
Feb 8, 2008 at 6:37 PM
