1994 Toyota Corolla location of fuel filter
1994 TOYOTA COROLLA
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHERRY DICKERSON
where is fuel filter located on this model/how to replace
May 29, 2010 at 4:05 PM
MMPRINCE4000
  • 8,548 POSTS
Be VERY carefull with lower double inverted flare connection. ONLY use a tubing wrench and soak in PB blaster.
If you crossthread the lower connection, you will have to replace the steel fuel line from pump.
May 31, 2010 at 7:35 AM
