1994 Toyota Corolla A/C blowing hot air during summer
1994 TOYOTA COROLLA
238,000 MILES • 4 CYL • 2WD • AUTOMATIC
DHANDAPANI
In normal weather the AC works fine. But when the outside temperature goes beyond 100 degrees then the AC starts blowing hot air. I live in Dallas and can you please the area I need to focus.
Jul 1, 2009 at 4:41 PM
BUDDYCRAIGG
  • 2,262 POSTS
it could be simply low on freon and the expansion valve is freezing up.
Do you have a set of AC gauges to take pressure readings?
Nov 19, 2018 at 5:25 PM
DHANDAPANI
No. I will purchase that and I will check the pressure readings.
BUDDYCRAIGG
  • 2,262 POSTS
take your time and look around, you should be able to find a cheap set for about 40 bucks.
That's what I paid for my first set and they lasted 3 summers and countless cars before i replaced them.
so they should be just fine for your occasional use.
