water leakage
1993 TOYOTA COROLLA
VIJUMJ
Engine Cooling problem 300000 miles
Pls help me,
Water leaking from the radiator. I could not see any out side leakage. I have cleaned the radiator and checked for any damage. it is Ok. I week before, water was mixing with oil. there was a crack in the Egine head. So the mechanic changed the head and gasket. but still water is reducing from the radiator. I checked the connection hose. there is no water drops out side. so what can be teh problem ? what parts I need to replace
Pls help me.
Viju
Mar 11, 2008 at 4:58 AM
MMPRINCE4000
  • 8,548 POSTS
Is the car burning coolant out the exhaust? Is there still coolant in the oil?
The radiator is relitively simple to remove, then have it pressure tested if you do not see an obvious leak, or replace it with a new one (about $120 for the part).
Mar 11, 2008 at 7:38 AM
