1993 Toyota Corolla Transmission fluid leak
1993 TOYOTA COROLLA
MIKE8096
Transmission problem
1993 Toyota Corolla 4 cyl Front Wheel Drive Automatic 190k miles
My car has a major transmission fluid leak. I have pinpointed the leak to the transmission fluid reservoir. I have the car on jacks and fluid is dripping from the reservoir on the inside part of the reservoir. How do I make repairs?
Aug 29, 2008 at 11:58 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I am not sure what you mean by the transmission reservoir? are you referring to the transmission sump? if so, this is usually a case of removing the sump and replacing the gasket, this is an easy if messy job, just don't over tighten the gasket and don't use any sealant either. If you require any further information re post your question.
mark (mhpautos)
Aug 30, 2008 at 12:40 AM
MMPRINCE4000
  • 8,548 POSTS
To add to what Mark said, there is a coolant reservoir, a winshield washer fluid reservoir, a power steering reservoir, and brake fluid reservoir.
Is the fluid red? Most trans. leaks are from the axle seals and the cooler lines to the radiator.
Aug 30, 2008 at 5:56 AM
