My 93 toyota corolla 1.8 is having surging problems. I have tested the fuel pressure and it is getting plenty of pressure. The cars idle will go up and down in "P" or "N" when I put it in drive and step on the pedal it try's to choke out, then when driving it surges.
I have replaced the fuel pressure regulator, TPS, IAC, 02 sensor, tune up, tested the coil in Distributor, checked and fixed vacuum leaks, Replaced the Computer, fuel filter, compression test, coolant pressure test and I am out of ideas please help.
Nov 5, 2009 at 7:54 PM
