Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Computer
Monitor Not Resetting
1993 Toyota Corolla speed monitor
1993 TOYOTA COROLLA
195,600 MILES • 4 CYL • 2WD • AUTOMATIC
JOE_GINGER
MEMBER
1 POST
FOLLOW
the speedometer does not work. Do you think it could be a fuse or the sensor?
Feb 18, 2009 at 7:27 PM
MMPRINCE4000
CERTIFIED EXPERT
Check fuses first, then check wiring to VSS (speed sensor), if OK, then replace VSS. If problem persists, it could be the speedometer itself.
Feb 19, 2009 at 7:56 AM
