[quote:7cb71d62b1="rasmataz"]Could be the plugs, wires, coil, vacuum leaks, fuel pressure problem, injector and engine compression[/quote:7cb71d62b1]
I have change plugs,wires,distributor cup, rotor, fuel pressure regulator, oxygen sensor, injector, 0 ring of injector and cooland temperature sensor. Check the ignition coil resistance, the air intake temperature sensor, map sensor, throttle position sensor vacuum hoses for vacuum leaks and are okay. Except the hydrocarbons no other problem has been the engine. Start without problem and has good acceleration.
Sep 30, 2010 at 12:27 PM
