1993 Toyota Corolla frozen locks
1993 TOYOTA COROLLA
SIDGYPSY
1993 Toyota Corolla 4 cyl Automatic 140,00 miles
locks are frozen/stuck shut..
i can get the key in but it won't turn all of the way.
i did get in one door and even from the inside you can't pull the locks up.
i received some advice.
and now i need to figure out how to get the door panels off..
where can i find that information?
you know...where the bolts are and everything.
thanks for looking..
have a good day.
-jason
Dec 4, 2008 at 1:43 PM
MMPRINCE4000
  • 8,548 POSTS
Use the car repair link in this thread or get a Haynes manual.
The larger problem is that the dew wipes (the squegge rubber thing that seals the window from water intrusion) are probably hard and brittle due to age and letting water inside the door.
You can also buy lock lubricant that will help "unfreeze" the lock and help with further icing problems.
Generally , you remove the inside door handle (remove screw covers), the window crank or power window switch, and the interior door handle. The panel pops out, it is held in place with plastic retainers. The outside door handle is bolted to the door frame from the inside.
Dec 5, 2008 at 6:54 AM
