1993 Toyota Corolla Door handle replacement
1993 TOYOTA COROLLA
LINDYLOU961
1993 Toyota Corolla 330000 miles
I purchased a new front exterior door handle and would like instructions for installation without destroying the inside door panel.
Oct 27, 2008 at 12:31 PM
MMPRINCE4000
  • 8,548 POSTS
You have to remove the door handle screws (usually conceiled behind a trim strip on the handle), the interior door handle, the window arm or power window switch.
The panel pulls off, then pull back the door water guard. The handle is held in place by two bolts. Be very carefull removing them so as not to bend them.
Oct 28, 2008 at 10:02 AM
MMPRINCE4000
  • 8,548 POSTS
A Haynes manual or the car repair link in this thread will also give you reference material to read.
The bolts that hold the handle to the door skin must be removed with care so as not to bend the door panel.
Aug 8, 2009 at 9:01 AM
