Hello
The technical manual shows that it is more like RTV Sealant than a gasket. I have attached the OEM specs.
Apply seal packing to the oil pan as shown in the illustration.
Seal packing: Part No.08826-00080 or equivalent
"¢ Install a nozzle that has been cut to a 3 - 5 mm (0.12-0.20 in.) opening.
HINT: Avoid applying an excess amount to the surface.
"¢ Parts must be assembled within 1 5 minutes of application. Otherwise, the seal packing will be of no effect.
"¢ Immediately remove nozzle from tube and reinstall cap.
Make a small donation! (We will make sure your question will be answered promptly and it will help us be able to continue to help others - Thanks)
Oct 22, 2008 at 12:02 AM
