1992 Toyota Corolla How to replace outside door handle
1992 TOYOTA COROLLA
95,000 MILES • 4 CYL • 2WD • MANUAL
SPANEDA1118
I took out the inside door handle but I can't figure out how to remove the window handle roller. I try to fry it with screw driver but it won't come out. I'm afraid that I will break it. I wonder if the handle roller is just an snap on or with screw. I already un-snap the door panel. What is left is this handle roller. I broke my outside door handle and I want to replace it.
Oct 3, 2008 at 11:22 AM
MMPRINCE4000
  • 8,548 POSTS
It is held in place with a sort of "C" clip. There is a tool you can buy at most auto parts stores.
You could use a small pick, point the handle down (rotating knob at 6:00). Use a small pick to pull the clip straight up, and the handle will come off.
Oct 4, 2008 at 7:59 AM
