1992 Toyota Corolla car stop n cant start
1992 TOYOTA COROLLA
AMIN
Electrical problem
1992 Toyota Corolla 4 cyl Four Wheel Drive Automatic
dear,
twice this week on the way car stop in between on the busy road cant restart on first occasion a mechanic came with a spare batteryn started by using the connecting the booster wires on other occasion a car push from the back for quite long than i put 2nd gear n apply the break and the car started. please suggest, in between iwas using ac. thank you
Jun 30, 2008 at 3:53 PM
Do you have a check engine light On prior to this problem?
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jun 30, 2008 at 4:00 PM
KHLOW2008
  • 41,814 POSTS
Hi amin,
If it stalled and could not crank, then you need to test the battery and check the charging system.
Jul 1, 2008 at 12:56 PM
