1991 Toyota Corolla location of oil pump
1991 TOYOTA COROLLA
92,000 MILES • 4 CYL • FWD • AUTOMATIC
VINCEMILLAN
where is the oil pump located and how hard is it to change. what are symtoms of oil pump failure
Jun 6, 2009 at 3:15 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, see text for oil pump removal, check oil pressure with a mechanical gauge, refer to specs, check for bearing knock and low supply to over head gear. mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Noname_71.jpg
Jun 6, 2009 at 9:23 PM
MMPRINCE4000
  • 8,548 POSTS
Measure oil pressure with mechanical gauge first.
Oil pump is on front of crankshaft. You must remove oil pan and that requires raising the engine for access to rear pan bolts.
Jun 7, 2009 at 7:49 AM
