Electrical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
The car was doing fine I had the AC on and the fan was blowing hard and all of a sudden the fan was not as hard and the AC was not as cold no engine light came on and I was going shopping ,after I was done shopping I got into the car and I went home I was not using the AC because I thought that it might be low on freon, but the car died and I checked the voltage in the battery and it was at 10.30 volts and was not enough to restart the car I jumped the car and got it running agin and tested the voltage and it was not chargeing I had expected 13-15 volts but there was no charge at all, I took the alt to Oriley`s
and put it on the growler and it passed all 3 tests
so I started up yhe motor and pulled the positive post off and it died I tested all of the fuses that I could find and they all tested ok and it still will not charge is there some fuses that I dont see? or is there a seperate voltage regulater and where is it located coul it be that the alt will test fine as long as there is not a load put on it?
Mar 1, 2009 at 6:30 PM
