1991 Toyota Corolla help me
1991 TOYOTA COROLLA
155,000 MILES • 4 CYL • 4WD • AUTOMATIC
ELEAZAR MOLANO
how can i turn off the radiator fan.as soon as i turn on the ednishion the fan turns on what do you think is rong with it i know its not the fan sensore and cooler sensore also the fan switch sensor and the relay becuase i already changed it what do you supose it could be pls write back a as soon as possible. thank you.
it should only turn on when the car is heated and turn off as soon as it cools off but i does not?!?!?!?!?!?!?!?!?!
Aug 17, 2010 at 6:35 PM
Next step will be the wiring and the computer
Aug 17, 2010 at 6:41 PM
MMPRINCE4000
  • 8,548 POSTS
There is a sensor under distributor between the lower hose connection to the coolant block.
This is the sensor that trips the cooling fan. Round white connector. First make sure it is connected, if it is replace it.
Aug 18, 2010 at 7:45 AM
