Engine Performance problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
1991 Toyota Corolla - 4FAE Engine Type. Automatic.
VIN: 2T1AE94E6MC074888. Mileage: 216,834 kms
Concern: Failed emissions test
1st test:
ASM2525 Curb Idle
Limit Reading Limit Reading
HC ppm 68 39 200 19
CO % 0.38 0.02 1.00 0.00
NO ppm 789 1305 N/A N/A
RPM 1876 RPM 898
Dilution 14.5 Dilution 14.4
Repairs Performed:
• Replaced Catalytic Converter
• Replaced 02 Sensor
• Changed Oil & Filter (Synthetic)
• Replaced Spark Plugs
• Replaced Air Filter
• Drove vehicle 150kms
2nd test:
ASM2525 Curb Idle
HC ppm 68 67 200 23
CO % 0.38 0.00 1.00 0.00
NO ppm 789 2374 N/A N/A
RPM 1865 RPM 1023
Dilution 14.0 Dilution 14.0
Other Notable Issues and Repairs:
• Slow to start cold: Turns but doesn’t fire. Leave ignition on for 3-5 seconds and its okay.
• Fans come on with ignition (Defrost and A/C not engaged) Replaced Fan Switch - Okay
• Cleared all codes - Ran to operating temp and re-tested: Code 43 (Starter/Ignition/ECU) Didn’t repair, Code 22 (Coolant Temp Sensor) Replaced Coolant Temperature Sensor – still get Code 22. Check engine light only comes on when accelerating from standstill, goes away at cruise or decel.
• Oil Light comes on (solid) as vehicle warms up. Not noted earlier as: Check Engine Bulb & Oil Lamp Bulb had been removed. No engine noises noted. Replaced Sender - Okay
• Compression 180psi all cylinders.
• New plugs and oil exceptionally clean (lean burn?), however, has only been run for 250kms.
Other Repairs Performed:
• Cleaned Throttle Body
• Ran 2 cans of combustion cleaner through engine
• Replaced Fuel Filter and PCV Valve
• Rewired 02 Sensor (Connector had been crossed I verified on known good car & wiring diagram)
• Retarded timing 2 degrees
• Filled with 91 Octane fuel
3rd test:
ASM2525 Curb Idle
HC ppm 68 66 200 42
CO % 0.38 0.48 1.00 0.07
NO ppm 789 1136 N/A N/A
RPM 1895 RPM 930
Dilution 15.5 Dilution 14.4
1st test:
ASM2525 Curb Idle
HC ppm 68 39 200 19
RPM 1876 RPM 898
Repairs Performed:
2nd test:
ASM2525 Curb Idle
HC ppm 68 67 200 23
RPM 1865 RPM 1023
3rd test:
ASM2525 Curb Idle
HC ppm 68 66 200 42
RPM 1895 RPM 930
Apr 11, 2009 at 3:17 PM
