Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine Cooling
Thermostat
1990 Toyota Corolla THERMOSTAT
1990 TOYOTA COROLLA
165,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS33141
MEMBER
1 POST
FOLLOW
CAR TEMPERATURE GOES UP REALLY HIGH, BELIEVE IT IS THE THERMOSTAT THAT NEEDS TO BE CHANGED. WHERE IS IT LOCATED?
Jan 12, 2010 at 7:40 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
follow the lower radiator hose back to the engine and thats where the thermostat housing should be.
Jan 12, 2010 at 9:47 AM
MMPRINCE4000
CERTIFIED EXPERT
On this engine it is lower hose that connects to thermostat housing directly under distributor.
Use a Toyota part and make sure the thermostat weep hole is pointing at 11:00 when installed, replace thermostat seal.
Jan 12, 2010 at 12:47 PM
