1990 Toyota Corolla gas tank
1990 TOYOTA COROLLA
JACKOLSON
  • 67 POSTS
Engine Performance problem
1990 Toyota Corolla 4 cyl Front Wheel Drive Manual
how do you clean, purge, a gas tank, i mean clean it out take out the grime and dirt of years of use, without having to do a lot of disassembly perhaps
thanks
Feb 24, 2010 at 11:56 AM
MMPRINCE4000
  • 8,548 POSTS
Yyou really need to remove tank and flush with solvents.
While you could fill with solvent then siphon out, you will not get it completely clean.
There are also products that you can pour in an empty tank and coat the inside with the product. This will give you a new inside, but you have to remove tank to get all gas out and any large particles.
Feb 25, 2010 at 6:59 AM
