Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Corolla
Ignition
Distributor
Replace/Remove
1990 Toyota Corolla distributor
1990 TOYOTA COROLLA
100,000 MILES • 4 CYL • FWD • MANUAL
NADIN
MEMBER
1 POST
FOLLOW
how to replace distributor oil seal,
Feb 23, 2008 at 3:01 AM
CERTIFIED EXPERT
Make a mark at the distributor base and engine block-remove the distributor cap mark the position of the rotor tip and the housing. then pull it out-replace the seal. going back in make sure you match all the marks if not the timing will be off.
Feb 23, 2008 at 3:12 AM
