1990 Toyota Corolla distributor
1990 TOYOTA COROLLA
100,000 MILES • 4 CYL • FWD • MANUAL
NADIN
how to replace distributor oil seal,
Feb 23, 2008 at 3:01 AM
Make a mark at the distributor base and engine block-remove the distributor cap mark the position of the rotor tip and the housing. then pull it out-replace the seal. going back in make sure you match all the marks if not the timing will be off.
Feb 23, 2008 at 3:12 AM
