1990 Toyota Corolla blinker short
1990 TOYOTA COROLLA
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARKESTLIN
hi i was recently putting a cd player into my corolla when shortly after my blinker and door sign shorted out , i checked and changed all the fuses but still no life what should i do
Jul 28, 2008 at 11:00 AM
MMPRINCE4000
  • 8,548 POSTS
More than likely you have an open wire that is shorting to ground, or a wire connected incorrectly.
I would remove the CD and restore to original and see if the problem goes away. If it does, then that would confirm the short or wire connected incorrectly.
Best thing to do when installing aftermarket electronic equipment is to use a harness that connects directly to original harness then to CD. Cutting and splicing wires can cause trouble.
Jul 29, 2008 at 6:43 AM
