1989 Toyota Corolla Replacing head, what can i reuse?
1989 TOYOTA COROLLA
70,000 MILES • 4 CYL • FWD • AUTOMATIC
JDWILSON4
For my new reconditioned cylinder head, that comes with valves and springs, etc allready installed, can i use my old camshaft on this head? or the cam followers? what about cam bolts? etc..
Jan 18, 2008 at 10:28 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You can re use all those parts, but the caution is with the cam shaft caps. As these are machined as a unit, Head & caps, it is a little strange that they have not supplied the original cam bearing caps. The cam will not be a worry as the bolts, just make sure the threads in the head are sound and you torque the bolts as per specs. If the head bolts are torque to yield, they will have to be replaced (no exemption) and all other parts will be ok, just the cam caps are a worry. i would ask the question of the head supplier.
Mark (mhpautos)
Jan 19, 2008 at 4:02 AM
