My cooling fan is on right from start up when cold and does not turn off? I also have a check engine light that popped up and I think its related.
Aug 27, 2010 at 10:40 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
coolant temp. sensor most likely fault but will want to retrieve the trouble code(s) stored to make sure
Aug 27, 2010 at 5:52 PM
CERTIFIED EXPERT
Jumper Te-1 to E-1 in the check connector to flash the code/s
Aug 27, 2010 at 5:57 PM
MMPRINCE4000
CERTIFIED EXPERT
There is a small white round connector under dist. in coolant block, this is fan switch.
Either fan switch is bad or relay is stuck. Check connection to fan switch.
Check fan relay's and "engine main" relay.
Aug 28, 2010 at 8:12 AM
DEVO357
MEMBER
If I forgot to mention this motor has a carburetor
Here are the code I pulled.
22
31
41
Aug 30, 2010 at 11:23 AM
GEET
MEMBER
22 is for coolant temperature sensor
31 is for vacuum sensor
41 is for throttle position sensor
Aug 30, 2010 at 11:41 AM
DEVO357
MEMBER
[quote:06412f7f96="geet"]22 is for coolant temperature sensor
41 is for throttle position sensor[/quote:06412f7f96]
Hmm I dont see how 41 is TPS the motor has a carburetor.
So what do I need to do to get rid of these codes?
Aug 30, 2010 at 2:25 PM
MMPRINCE4000
CERTIFIED EXPERT
Disconnect the battery (-) for 5 minutes to erase codes, if they come back on, then further repair is necessary.
Aug 31, 2010 at 8:22 AM
GEET
MEMBER
[quote:518e7b68cd="mmprince4000"]Disconnect the battery (-) for 5 minutes to erase codes, if they come back on, then further repair is necessary.[/quote:518e7b68cd]
if they come back you have to change the sensor. its weird you have carburetor and it stores code 41.
Aug 31, 2010 at 12:43 PM
MMPRINCE4000
CERTIFIED EXPERT
It is also possible the ECM is bad, or that some 89's had FI but used a common ECM with a different PROM.
