1989 Toyota Corolla Blower
1989 TOYOTA COROLLA
Air Conditioning problem
1989 Toyota Corolla 4 cyl Two Wheel Drive Automatic
Hello....I am looking to locate the resistor for the blower moter ....I think this may be why its not working...As it makes a clicking noise...but it does not operate at any speed.....Where is the resistor located and do you think this is the problem....Thanks Dan
Mar 14, 2010 at 1:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the blower motor resistor is behind the right side of the dash, on top of the cooling unit. but if its not working on any speed at all then i would not suspect it to be the cause. the clicking is probably just the relay you hear, the blower motor may still be at fault. check the fuse to the blower first.
Mar 14, 2010 at 2:20 PM
