1988 Toyota Corolla TAIL LIGHTS
1988 TOYOTA COROLLA
112,000 MILES • 4 CYL • AWD • AUTOMATIC
DEVSITARAM
WHEN I PARK THE CAR,RENOVE THE IGNITION KEY THE BRAKE LIGHTS GO ON.WHEN I PRESS THE BRAKE PEDAL THE LIGHT GOES OFF AND COMES BACK ON IN A FEW MINUTES AND STAYS ON DRAINING THE BATTERY.WHAT SHOULD BE DONE TO CORRECT THE PROBLEM.
THANS!
DEV
Jun 14, 2008 at 7:14 AM
MMPRINCE4000
  • 8,548 POSTS
Replace the brake light switch which is mounted on the top of the brake pedal under the dash.
Jun 14, 2008 at 8:06 AM
KHLOW2008
  • 41,814 POSTS
Hi devsitaram,
Sorry mmprince4000 for cutting in.
Check the switch to pedal clearance or a damaged stopper first.
Jun 14, 2008 at 10:44 AM
MMPRINCE4000
  • 8,548 POSTS
[quote:1c43970104="KHLow2008"]Hi devsitaram,
Check the switch to pedal clearance or a damaged stopper first.[/quote:1c43970104]
No problem.
Jun 15, 2008 at 6:35 AM
