1988 Toyota Corolla SPUTTERS
1988 TOYOTA COROLLA
196,000 MILES • 4 CYL • FWD • AUTOMATIC
MADAHAM
hi my 1988 toyota corolla sputters when i put it in gear and put a load on the engine. it idles just fine but when i accelerate or go up a hill it loses power. i changed the spark plugs and airfilter and it runs a lot better but still has a bit of a miss when i put it under a load.
Feb 15, 2010 at 2:23 PM
Hi MADAHAM, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs-if okay check and test for an excessive backpressure in the exhaust system-could be a partially clogged catalytic converter also the following-airflow meter and throttle position sensor-
Feb 15, 2010 at 4:41 PM
