1988 Toyota Corolla cv joint
1988 TOYOTA COROLLA
186,000 MILES • 4 CYL • 2WD • AUTOMATIC
DWELDYJ
I cant seem to get my passenger side cv joint popped loose from the transmission is there some trick to it or what?
Apr 1, 2008 at 5:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The C.V. is just located with a "C" clip, but they can be stubborn some times, just use a sutable lever between the shaft and the box, lever with a jerk action, and rotate the shaft a bit and try again, it should pop out with out too much worry.
Mark (mhpautos)
Apr 2, 2008 at 5:35 AM
