To add to great advice by Raz.
Connect diagnostic terminals with engine off, ign. off.
Connect timing light to battery and inductive pickup to #1 (closest to timing belt).
Start engine (it will run slow and check engine light will flash every second).
Adjust dist. (loosen bolts) to 10 degrees BTDC.
Turn engine off, remove diagnostic connectors.
Oct 31, 2009 at 8:38 AM
