1986 Toyota Corolla Dirty Intake Manifold
1986 TOYOTA COROLLA
140,000 MILES • 4 CYL • 2WD • MANUAL
ISOD
  • 4 POSTS
I am currently replacing the combination intake/exhaust manifold gasket on my 1986 Toyota Corolla SR5 Carb'd.
I noticed that the intake manifold itself has a large amount of soft carbon build-up. Does this mean that the engine is heavily polluted as well? Should I dismantle the engine completely for a more thorough cleaning? I am currently trying to pass California smog testing.
Apr 22, 2008 at 4:09 PM
ROB2008
  • 258 POSTS
Usually carbon build up means a lean air and fuel mixer .. that could be as simple as a O2 sensor .. or your carburetor could be out of adjustment .
Apr 22, 2008 at 5:07 PM
ISOD
  • 4 POSTS
[quote:25ebad9252="Rob2008"]Usually carbon build up means a lean air and fuel mixer .. that could be as simple as a O2 sensor .. or your carburetor could be out of adjustment .[/quote:25ebad9252]
You bring to light something I don't know how to adjust and that's the carburetor. I have yet to fire this old engine back up, and I haven't replaced the old o2 sensor. I don't know if the o2 sensor is a recent replacement, as i've just gotten the car.
My main concern for many engines is the fact that the inside of intake manifolds get so crusty and sooty. Doesn't that mean some sort of putrification within the engine case? It probably does, so my next question is: what section of the engine block are likely to be dirtiest in a Toyota 4A-C 1986, or for any aging gas engine?
Apr 22, 2008 at 7:12 PM
ROB2008
  • 258 POSTS
I would say the dirtiest part in an aging engine block is the combustion camber .They make fuel additives that are supposed to clean it out easily or you could take the cylinder head off and inspect it .
Did the vehicle run when you received it ?
Apr 23, 2008 at 10:45 AM
ISOD
  • 4 POSTS
[quote:2691598c6f="Rob2008"]I would say the dirtiest part in an aging engine block is the combustion camber .They make fuel additives that are supposed to clean it out easily or you could take the cylinder head off and inspect it .
Did the vehicle run when you received it ?[/quote:2691598c6f]
This vehicle was running when I first received it. I am still in the process of cleaning out the manifold, and will inspect the combustion chamber next. Guaranteed 2 Pass cleaner from Kragen was used once on this car.
Apr 27, 2008 at 2:47 PM
