1979 Toyota Corolla DISTRIBUTOR & FIRING ORDER
1979 TOYOTA COROLLA
YOLLY
Engine Mechanical problem
1979 Toyota Corolla 4 cyl All Wheel Drive Manual
2TGEU TOYOTA ENGINE
PLEASE SEND DISTRIBUTOR TIMING?
WHERE DOES ROTOR LAY? BEFORE OR AFTER 1?
WHAT DEGREE MUST THE CRANK BE ON?
Much appreciate it,
Thank you.
Oct 21, 2009 at 6:45 AM
MMPRINCE4000
  • 8,548 POSTS
Timing is 10 degrees BTDC, rotate engine to TDC #1, rotor should be pointing directly at #1 spark plug wire, if not adjust dist. so it does.
Then set at 10 degrees with timing light.
Oct 24, 2009 at 9:34 AM
