idles really high
TOYOTA CELICA
THE_HYDROXIDE_CHILD
  • 82 POSTS
ok i have a 93 toyota celica 2.2L... for some reason whenever i use the battery without the car running like listening to my radio or accidentally leaving a light on... when i start the car id idles really high at 3000 rpm and doesnt drop at all... if u ever barely touch to gas is shoots up to 5000 if u wait about 15 to 20 minutes it all goes back to normal... i was thinking maybe the car is tryin to hurry up and charge the battery but im clueless please help
Sep 29, 2007 at 12:34 AM
MERLIN2021
  • 17,250 POSTS
does it do this only with a cold engine? If so try the electronic coolant temp sensor (ECT).
Sep 29, 2007 at 5:28 AM
THE_HYDROXIDE_CHILD
  • 82 POSTS
no even when the engine has warmed up it still does it...
Sep 29, 2007 at 11:46 PM
Hello there kid, long time no see you in here huh!
Have you considered checking up on your accelerator cable if its binding in the sleeve, also for a TB plate all coked-up with nasty stuff
You sure you don't have a vacuum leak somewhere that opens up when the engine is cold and when it heats up it closes-start spraying it after you hit the key.and when you hit the sweet spot it will react this is where your bad friend is located. Go do it.
My brother magicman gave you a head start on the ECT, that one controls the fuel enrichment during the inital cold start when the computer don't see the correct signal from it,it will lock it in open loop mode-meaning the ECM will be dumping fuel when its not needed, also w/n tell the Snitchers to take over the A/F mixture meaning the oxygen sensor in closed loop.
You learn again-from the old timers-don't worry magicman is my younger brother we're here together to help people like you.
Its nearly 6mos. since the last time I seen you in here. Look at my signature, if you could-do it we need help here.
Oct 2, 2007 at 5:29 AM
